| | | Forums66 Topics128,268 Posts1,058,378 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#26533 02/22/2003 7:22 AM | Joined: Sep 2002 Posts: 25 New Guy | | New Guy Joined: Sep 2002 Posts: 25 | Need some help want to change front wheel bearings from original ball bearings to roller bearings if someone has a number and make I could get them locally. Need numbers for both inner and outer, I have a 45 GMC 1/2 ton. | | |
#26534 02/22/2003 5:51 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | I believe the roller bearings are special units sold from old truck vendors and not commonly available in local auto or bearing parts houses.The stock ball bearings work just as well if in good shape.We had a good discussion last year on bearings, some guys with knowledge stated the roller bearing offered no advantage unless they are less expensive. | | |
#26535 02/26/2003 1:34 PM | Joined: Dec 2002 Posts: 55 Member | | Member Joined: Dec 2002 Posts: 55 | 45- I just bought those bearings from a truck parts company - I kept the boxes and #'s ...made in Japan, if I remember correctly. I'm at work now but will post manuf & #'s off box when I get home PM. | | |
#26536 02/28/2003 4:35 PM | Joined: Dec 2002 Posts: 55 Member | | Member Joined: Dec 2002 Posts: 55 | The inner front bearing is branded "MBS" and is # 909052R. The outer is also MBS & # 909001R. The seal is a "Federal Mogul" # 6064. The MBS says made in Japan, and the cones and cups are packaged together as a set. They fit great. Hope this helps - let us know if you find them at a local bearing house. | | |
#26537 02/28/2003 7:22 PM | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | Interesting web page... :p :p Japanese Bearing Manufacturer
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
#26538 03/02/2003 4:39 AM | Joined: Sep 2002 Posts: 25 New Guy | | New Guy Joined: Sep 2002 Posts: 25 | Thanks guys for your help in giving bearing #s,and for the site of MBS bearings. Would have got back sooner but forgot I'd posted for the information. Yopu can always trust on the STOVEBOLTERS. | | |
#26539 03/03/2003 3:06 PM | Joined: Dec 2002 Posts: 55 Member | | Member Joined: Dec 2002 Posts: 55 | That's a neat site, blue. I printed the dimensions for the truck bearings, just in case I need them for reference. | | |
#26540 03/04/2003 2:52 AM | Joined: Dec 2002 Posts: 55 Member | | Member Joined: Dec 2002 Posts: 55 | I goofed up - the #'s above are for an AD truck - not sure about the 45. Would be worth checking the Japanese site. | | |
