| | | Forums66 Topics128,154 Posts1,056,855 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2002 Posts: 55 Member | | Member Joined: Nov 2002 Posts: 55 | I have an opportunity to buy a 3 speed overdrive manual transmission for my task force truck. I've been wanting to add overdrive.
Assuming it works ok, what's a fair price? I'm in California if it matters.
Thanks | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | I don't know, but if you don't buy it let me know and I will drive over and buy it. I would like to try one of those some day.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | I bought a 3 speed with overdrive out of a 57 car for $75.00 at the spring Carlisle swap meet in Pennsylvania. The side cover with the shifting forks was missing. I still thought it was a fair price. Gonna put it in my 52 3/4 ton. | | |
#2653 12/16/2004 12:53 AM | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | I have 4 of them, from the late fifties to the mid sixties (synchro first gear) models. Prices ranged from $300 to $125. Oddly enough, the best one cost the least, I think I caught the seller at a good time. Just make sure you get the solenoids that come with the trans. | | | | | Joined: Nov 2002 Posts: 55 Member | | Member Joined: Nov 2002 Posts: 55 | Thanks for the input.
I offered the guy $250. Haven't gotten an answer yet.
Sounds like a lot but these OD transmissions are not that easy to find.
LT | | | | | Joined: Jan 2004 Posts: 112 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 112 | Hey LT, If this is the guy on Craig's list that want $800 for the 235 and OD transmission, I would advise caution. He doesn't have the solenoid (very hard to find) and says the opening where it goes is "plugged" with something. He told me he wants to get $450 for just the tranny. I just bought a 1957 "R10H-1A" Borg Warner OD complete with harness, govenor and solenoid in south San Francisco today for $150. Pulled the side cover and it look like new.
| | | | | Joined: Aug 2004 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 196 | my sons 67 chevelle has one it was a 600. option if it was me id rather have a car 4 speed or a newer 5 speed | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | I agree, the prices do vary mostly due to the seller and buyer. If you can wait, you can find a complete unit including solenoid, switch and harness for less than two hundred or if you just gotta buy it I've seen them go for three hundred without all the other stuff. I have several and plan on using them on my fleet, I've picked up parts on ebay occasionally cheap. If you can get it reasonably complete, two fifty isn't bad, at least you will have it! I think I have seen a post here, that talks about setting one of these up without all the original parts. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I bought my OD transmission for $100. It came with the Solenoid and Governor. I didn't want to bypass the other electrical components so I searched around and found the relay, kickdown switch, and kickdown switch bracket. I bought the wire harness from Jim Carter.
All in all, I think I paid about $200 for the whole set up.
PRICELESS
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Jan 2002 Posts: 2,842 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,842 | LT, Give me his address and I'll make him an offer he can't refuse for you....Hope all is going well with you in Saratoga.
Craig
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#2661 12/27/2004 10:12 PM | Joined: Nov 2002 Posts: 55 Member | | Member Joined: Nov 2002 Posts: 55 | | | |
