| | | Forums66 Topics128,154 Posts1,056,838 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#26463 12/31/2001 8:28 PM | Joined: Jul 2001 Posts: 149 Member | | Member Joined: Jul 2001 Posts: 149 | I heard two old fellas discussing aluminum heads on a cast block. They were saying that it causes problems due to the differnt type of metals. That the two metals dont match and eventually one of the two will warp and not seal properly. Is this this true? Thanks!
"Finish the thing, do it right the first time, and drive the S.O.B.!"
1949 Chevy half ton 3100 In a kazillion pieces 2000 GMC Serria 1500 SL 4x4
#26464 12/31/2001 10:43 PM | Joined: Apr 2001 Posts: 39 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 39 | MALLARD we run alum heads on iron block in our racecar 622cid 2 stages of nos and no problem most of the new gm v8s are alum heads we use a copper haed gasket
47 Chevy COE..52 TO 30
#26465 12/31/2001 11:33 PM | Joined: Nov 2001 Posts: 16 Member | | Member Joined: Nov 2001 Posts: 16 | Hi, it sounds like the discussion was about the two metals not heating and cooling at the same rate, which is true, but a good quality head gasket will keep it from causing a problem prematurally. Hope this helps to answer your question....Chb46 | | |
#26466 12/31/2001 11:45 PM | Joined: Jul 2001 Posts: 149 Member | | Member Joined: Jul 2001 Posts: 149 | Thanks! That dose clear things up! I manage truckdrivers and that was who I was listening to. One of our VP's just got one of the Chevys with the Dura max engines and it has aluminum heads and all they could say was he's gonna have nothing but truble with it because of that. I fiqured it was just "truck driver talk" If your a truck driver you know what I mean. Thanks
#26467 01/01/2002 9:09 AM | | Anonymous Unregistered | | Anonymous Unregistered | Mallard, how in the world did you get hornswaggled into thinking you could manage truckers? :rolleyes: | | |
#26468 01/02/2002 5:13 PM | Joined: Jul 2001 Posts: 149 Member | | Member Joined: Jul 2001 Posts: 149 | I was tricked!!! After five years of trying to manage truck drivers Iam realizing they are un-managable! Its never a dull moment thanks for the info!
