| | | Forums66 Topics128,089 Posts1,056,437 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#26316 01/20/2003 5:28 PM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | Can you swap the 5.14 rear end pumpkin on a '51 1-ton with a 4.10 from a '67-'72 3/4T? 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#26317 01/20/2003 8:01 PM | Joined: Jul 2002 Posts: 188 Member | | Member Joined: Jul 2002 Posts: 188 | | | |
#26318 01/20/2003 8:18 PM | Joined: Jan 2003 Posts: 19 Member | | Member Joined: Jan 2003 Posts: 19 | Wally: If the 1 ton rear on your 48 is the same as a 3/4 ton rear you can purchase a 3.90:1 ring and pinion from Randy's Rear Ends. That would most definitely give you more interstateability. BuBBAB52 | | |
#26319 01/20/2003 10:47 PM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | Thanks. The fellow at NAPA who turned my rear drums said he had a '51 3/4T with a "5.10" rear end. It's either a 3/4T with a 4.57 or a 1T with a 5.14. Either way the swap would work and would be the cheaper way to get some more speed. Thanks, again. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
