4 members (jay d, Youngin' Tut 59, TooMany2count, 1 invisible), 83 guests, and 2 robots.
Topics128,139
Posts1,056,754
Members48,454
My Nov '53-vintage 235 pressure-oiler has apparently been fitted with undersized cam bearings. Looks like I need to put stock ones in. I can get 'em from Patrick's, but how do I get the old ones out and new ones in? The crank, rods, and pistons are in, and I'd just as soon leave them be.
The cam is a nominal 2.150, but I have mic'd both the journal and the bearing, and there's about 5 thou of mismatch.
What do I need to remove and refit new bearings?
I'm also considering taking the motor to someone to re-assemble. I got too many other projects. 8-( Can anyone recommend a shop in northern California/Sf Bay area?
Thanks!
George
If you had the block machined locally, ask them about finishing the job. To replace the cam bearings, the crank will probably have to come out. A good machine shop should have to tools to do that work.
Fred
52 3600
69 C-10
With the crank in, it may be a little more.
It should be around $30 bucks to have them replaced. If I were closer, I would do it for that.
Thanks.
The block was not machined. I bought it from a guy who bought it from a guy 8-) who had apparently rebuilt it. It's on its first overbore, I think - .040 over, no ridge and in general is in very good shape. I just wanted to add the 4MF (?) cam and headers for a little more top end. The truck is 4.46 rear gears and so it needs to spin a little for highway use. It's a 3/4 ton, 8-lug axle, so taller gears aren't quite so commonly available. Besides, I like the pulling power.
I'll find a local machinist willing to do it. $30 is reasonable. Heck, $50 wouldn't kill me.
Thanks!
George
