| | | Forums66 Topics128,045 Posts1,055,528 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#26044 06/09/2004 1:31 AM | Joined: May 2004 Posts: 43 Junior Member | | Junior Member Joined: May 2004 Posts: 43 | Well - I got her fired after who know how long she sat. It's a wonder what new points, coil, condenser, plugs, wires, cap and rotor will do. One shot of ETHER down the carb and she started idling pretty smooth.
After about two minutes, a loud squeal developed from the front end of the engine. I shut her down and re-fired. A couple of minutes later, same squeal.
I thought water pump, so I shut her down and pulled the pump. The impeller looks fine and the thing turns o.k. so my question is -
How do I know my water pump is o.k.???
Was the squeal coming from the OLD belt and rusty fan pully?
IDEAS?!?!
Thanks!
Dave | | |
#26045 06/09/2004 4:55 AM | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | Hmmm, seems like a water pump works or it doesn't. I've never had a water pump that worked only a little bit. I currently have a bearing that's on it's way out on my 292. There's a little bit of play and it makes a little noise. Stuff that spins definitely wears out. My heater blower motor is the opposite of your water pump. It makes a horrendous whining noise for about a minute after turning on then goes away. When I pulled it to check, of course it spins nicely with the five finger check. Try a stethoscope or styrofoam cup with a couple feet of garden hose to narrow it down. And obviously steer clear of the fan blades when troubleshooting. | | |
#26046 06/09/2004 5:53 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Try running it for a few seconds without the belt on to see if it is internal or pump/gen.
See the USA in your vintage Chevrolet! My Blog | | |
#26047 06/09/2004 2:58 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | You can also shoot some wd-40 on the belt and see if that quiets it down. Usually when a water pump fails coolant oozes out of the drain hole on the bottom side of the shaft hub.
Fred 52 3600 69 C-10
#26048 06/09/2004 3:47 PM | Joined: Feb 2000 Posts: 985 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 985 | squirting water on a belt while running will tell you if it is the belt or pump. Typically if the bearing in the pump starts to go bad it will take out the seal and the pump will leak. This isn't always true. With the pump installed try moving the fan blade tips to see if there is excessive play. With the pump off see if there is any wobble in the main Shaft. There should be very little to no play in the shaft. Good luck and let us know what you find.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
#26049 06/11/2004 12:46 AM | Joined: May 2004 Posts: 43 Junior Member | | Junior Member Joined: May 2004 Posts: 43 | Well thanks to the idea from "Pre '68 Dave", I took another look and found the generator was not turning. So I removed the GEN and pulled the back off. It looks like the armature is gunked up within thge field coils, or the front end bearing? is froze? I haven't yet got the pull off as it is 15/16ths, the one socket I don't (yet) have.
Any ideas or tips on what to do or NOT to do when working to free the GEN shaft? Can I spray it with PB Blaster or Wonder Drug 40?
Thanks! | | |
#26050 06/11/2004 3:26 AM | Joined: May 2004 Posts: 43 Junior Member | | Junior Member Joined: May 2004 Posts: 43 | I got it apart. Sprayed WD40 all over and things started to spin. Getting the pulley off was the big free-up move.
Upon re-assembly, the pulley seems to tighten things up a liitle too much. The shaft spins freely until I tighten the pulley nut down on the lock washer. Is there a torque spec on the pulley nut? Or should there be a bushing/spacer in there?
Thanks! | | |
#26051 06/11/2004 3:42 AM | Joined: Feb 2004 Posts: 29,755 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,755 | There should be a spacer between the front bearing and the pulley. It looks like a ring, about 1/8" thick or a little thicker. When the pulley nut tightens, this should allow the front bearing to spin freely without any drag between the armature and the front housing. Be sure to polarize the generator after reinstslling it, by taking the wire off the "Arm" terminal on the voltage regualtor, and touchung it to the "Bat" terminal briefly. Jerry
