| | | Forums66 Topics128,030 Posts1,055,424 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#25624 11/24/2004 10:07 PM | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | how much vacuum should i expect and the manifold where the wipers hook up? i took it apart and cleaned it but doesn't work much better. barely moved before now moves about half way then stops and won't come back. does seem to work smoother when you move them by hand. btw have a safe thanksgiving you all. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
#25625 11/24/2004 11:43 PM | Joined: Jul 2004 Posts: 102 Member | | Member Joined: Jul 2004 Posts: 102 | Mine gets about 20 to 25 inch pounds. My wipers don't work well either, but I'm sure it's my wiper motor.
1948 3600 thriftmaster
#25626 11/25/2004 12:00 AM | Joined: Nov 2004 Posts: 266 Custom Title | | Custom Title Joined: Nov 2004 Posts: 266 | At idle you should have 15-20 in.Hg. Under heavy loads/acceleration, vacuum can drop to 0. Under decelleration it can be as high as 25-27 in.Hg. Sounds like your wiper motor gave up the ghost.
49 Chevy 3600 65 Chevy K10 48 International KB-1 Service Truck 55 Willys CJ5 - Chevy 331 powered 26 Model T Roadster Rat Rod 70 Tucker Sno-Cat 442-A 96 Dodge 3500 Cummins dually flatbed x-cab 4x4 06 Jeep Wrangler LJ rock crawler If you can't fix it with a hammer, it's an electrical problem | | |
#25627 11/28/2004 6:16 AM | Joined: Sep 2003 Posts: 42 Junior Member | | Junior Member Joined: Sep 2003 Posts: 42 | Ron,
On my 54 I was having the same problem (even back when grandpa had the truck) The wipers never worked very well and grandpa took off the passenger's side wiper arm to give the driver's side more of a chance. Well after I bought the truck I wanted to see if there was anything I could do. I took the vacum wiper motor apart and cleaned 50 years of hard lubricant and placed on a thin coat of vasoline and it works rather well now, with both wiper arms attached.
I still have the typical slowing up and down going up and down grades, that's to be expected with vacum operated wipers, but still better than nothing. I have also heard sending the motor off and have it rebuilt will be a great help too. That and a dual action fuel pump.
I can't remember now what the vacum gauge reading was, this is how I found a easy fixed my problem.
John Niekamp
1954 Chevrolet 3800 series flatbed dump
#25628 11/28/2004 10:48 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Wy not one of the electric wiper changeover kits. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#25629 11/29/2004 9:20 AM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Or a '55.2-'57 electric wiper from a truck. | | |
#25630 11/29/2004 4:12 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I am told that the electric wiper motor replacement will not fit if there is an original radio in place. Can someone confirm this, please? | | |
#25631 11/29/2004 10:07 PM | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i was wondering the same thing about the radio because i took mine out to work in the wiper motor and there is not much room up there. i did drive it today at high way speeds and it would wipe all the way across and back after i cleaned it. electric seems the way to go but i just went back to work after a 6 months layoff, only so i could put money in the truck. i hated depleting my retirement funds for the truck. so i took a parttime job to supplement my retirement.does that make me a true stovebolter to go back to work to support a truck? no pet no wife, no worries.
#25632 11/30/2004 4:19 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Now that is dedication! The old trucks can get sick and cost money but they don't talk back to you! | | |
#25633 11/30/2004 3:55 PM | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | truckernix, you preach it and i will turn the pages. amen brother.
