1 members (Brian Moore), 55 guests, and 3 robots.
Topics128,030
Posts1,055,423
Members48,422
#25624 11/24/2004 10:07 PM
how much vacuum should i expect and the manifold where the wipers hook up? i took it apart and cleaned it but doesn't work much better. barely moved before now moves about half way then stops and won't come back. does seem to work smoother when you move them by hand. btw have a safe thanksgiving you all. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#25625 11/24/2004 11:43 PM
Mine gets about 20 to 25 inch pounds. My wipers don't work well either, but I'm sure it's my wiper motor.
1948 3600 thriftmaster
#25626 11/25/2004 12:00 AM
Custom Title
Custom Title
At idle you should have 15-20 in.Hg. Under heavy loads/acceleration, vacuum can drop to 0. Under decelleration it can be as high as 25-27 in.Hg. Sounds like your wiper motor gave up the ghost.
49 Chevy 3600
65 Chevy K10
48 International KB-1 Service Truck
55 Willys CJ5 - Chevy 331 powered
26 Model T Roadster Rat Rod
70 Tucker Sno-Cat 442-A
96 Dodge 3500 Cummins dually flatbed x-cab 4x4
06 Jeep Wrangler LJ rock crawler
If you can't fix it with a hammer, it's an electrical problem
#25627 11/28/2004 6:16 AM
Junior Member
Junior Member
Ron,
On my 54 I was having the same problem (even back when grandpa had the truck) The wipers never worked very well and grandpa took off the passenger's side wiper arm to give the driver's side more of a chance. Well after I bought the truck I wanted to see if there was anything I could do. I took the vacum wiper motor apart and cleaned 50 years of hard lubricant and placed on a thin coat of vasoline and it works rather well now, with both wiper arms attached.
I still have the typical slowing up and down going up and down grades, that's to be expected with vacum operated wipers, but still better than nothing. I have also heard sending the motor off and have it rebuilt will be a great help too. That and a dual action fuel pump.
I can't remember now what the vacum gauge reading was, this is how I found a easy fixed my problem.
John Niekamp
1954 Chevrolet 3800 series flatbed dump
#25628 11/28/2004 10:48 PM
Riding in the Passing Lane
Wy not one of the electric wiper changeover kits.
1972 Chevy c10 Cheyenne Super
#25629 11/29/2004 9:20 AM
Or a '55.2-'57 electric wiper from a truck.
1954 GMC De Luxe COE
#25630 11/29/2004 4:12 PM
I am told that the electric wiper motor replacement will not fit if there is an original radio in place. Can someone confirm this, please?
1951 1 Ton Completed
#25631 11/29/2004 10:07 PM
i was wondering the same thing about the radio because i took mine out to work in the wiper motor and there is not much room up there. i did drive it today at high way speeds and it would wipe all the way across and back after i cleaned it. electric seems the way to go but i just went back to work after a 6 months layoff, only so i could put money in the truck. i hated depleting my retirement funds for the truck. so i took a parttime job to supplement my retirement.does that make me a true stovebolter to go back to work to support a truck? no pet no wife, no worries.
2017 Buick Encore
See more pix
#25632 11/30/2004 4:19 AM
Now that is dedication! The old trucks can get sick and cost money but they don't talk back to you!
#25633 11/30/2004 3:55 PM
truckernix, you preach it and i will turn the pages. amen brother.
2017 Buick Encore
See more pix
