6 members (Tronman, wilbur53, Jon G, GMCJammer51, Hotrod Lincoln, 1 invisible), 85 guests, and 2 robots.
Topics128,109
Posts1,056,569
Members48,448
Junior Member
Junior Member
well i have had the panel 4 weeks today,she had been sitting -up for 28 years,i have put new plugs,wires,new brakes,new fuel-pump,had the radiator shop boil out gas tank (line in tanks was stopped up), they also used the red pour in lineing the tank, went on my first road test,,,,it went about one mile and cut off starving for gas????i took the gas line alose from tank added my plastic tank with rubber gas line had it hanging off the side of the truck,runs fine,come back hame blow air dowm thur tank with air hose (did not hear bubbling noise) but i did hold my hand over neck and air was coming out of gas neck,test ride 2 same distance +/-, put plastic tank hook-up and drove home,took gas line from tank out again,put air hose in filler neck with a rag so i could blow air in the tank,air came out the line in the tank(kinda a spray........
1950 Chevy Panel 310
Junior Member
Junior Member
cont'd.....) WHAT IS MY PROBLEM????????/ i have tried everything,i quess i need to pull the tank this eveing when i get from work and take it back to the rad. shop------what do you think????? all replies are appreciated....thanks
Working with the original tanks even if steam cleaned to the point that you think are clean there always seens to be some residual in the tank that causes problems. A full tank will have less problems than a 1/2 tank of gas. The 1/2 tank will slosh around more and get dirt in the line. I appear to have finally solved this by installing a perma-cool water/gas filter under the tank on the inside of the frame. Supposed to be a 2 micron filter and the filter has a water drain on the bottom. The cheapest place I have found them in in the Whitney Catalogue. They come with mountng brackets & Hoses. I did have to get some brass fittings to finish up. Make sure you put some thread sealer on the fittings & don't use the thread tape.
"Drugs are money, money is power, power is security." - Kent Heiner
Nedrow population 2212
Carbon footprint family of 2/11 tonnes of CO2/yr
How much gas did you put in the tank after getting it back in? It sounds out of gas. Maybe there wasn't enough, or it leaked out?
First thing to try is to add some and see if it starts. Then see if it leaks out anywhere.
54 3100 with 235
62 flatbed dump C60 with 261
Junior Member
Junior Member
well guys PANEL TRUCK UPDATE--------took gas tank off again,put carb cleaner in fuel line that is made inside the tank,took brass welding rod bent a 1/4 90 deg. turn on the end and put in drill,got all the gunk out of the line and put it back on,went on a 20 mile trip out of the driveway after work yesterday---------NICE!!!!!, stopped by a friend's house and he adjusted the carb,idel and air..........runs great,kinda slow got it up to 50 mph....but fun to drive-------amazing after sitting up for 28 years......only thing when i got home i found out the water pump started leaking-------oh well it always something-----------thanks
Quote
When the radiator shop "boils" a tank out, they normally check for leaks by doing a pressure test.
Putting gas in and checking for leaks is the last thing I'd want to do eek . But hey, what do I know, I like rope burns grin .
