1 members (Otto Skorzeny), 95 guests, and 1 robot.
Topics128,154
Posts1,056,856
Members48,456
Junior Member
Junior Member
My friend has a '64 Chevy truck 1/2 ton with a 230ci inline six in it. This summer I am going to install a small block chevy into it for him, and I am trying to find information on what I will need.
I am trying to find out what motor mount brackets I need, and if I can get them out of any other year truck. I am also looking for information on what oil pan I need.
Thanks for any information or suggestions you have.
Jeff
.I believe the stock oil pan will fit with no problem.
other things to look for will be linkages,exhaust and fan shroud.The fuel pump and starter are in the same general location,so hook up will be simple there.
Great link Kicks! grin
A picture is worth a thousand words............ cool
*** GMC ***
I don't know that much about a 60's model truck but i would check to see how differnt the Frount end under a 80's model c10 is. I just install a 85 c10 IFS in my 53 and had to throw away the monting stuff for it because i will not work with me from and frount end. I could be wrong but i was under the impression that the ifs didn't change that much. don't run out and buy one just check into it
brian
