| | | Forums66 Topics128,131 Posts1,056,723 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#25563 05/12/2002 8:29 AM | Joined: May 2002 Posts: 1 Junior Member | | Junior Member Joined: May 2002 Posts: 1 | My friend has a '64 Chevy truck 1/2 ton with a 230ci inline six in it. This summer I am going to install a small block chevy into it for him, and I am trying to find information on what I will need.
I am trying to find out what motor mount brackets I need, and if I can get them out of any other year truck. I am also looking for information on what oil pan I need.
Thanks for any information or suggestions you have.
Jeff | | |
#25564 05/12/2002 6:36 PM | Joined: May 2001 Posts: 46 Member | | Member Joined: May 2001 Posts: 46 | | | |
#25565 05/12/2002 7:01 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | .I believe the stock oil pan will fit with no problem. other things to look for will be linkages,exhaust and fan shroud.The fuel pump and starter are in the same general location,so hook up will be simple there.
#25566 05/13/2002 2:43 AM | Joined: Mar 2001 Posts: 316 Member | | Member Joined: Mar 2001 Posts: 316 | Great link Kicks! A picture is worth a thousand words............
*** GMC ***
#25567 05/13/2002 6:21 AM | Joined: Jan 2002 Posts: 3 Member | | Member Joined: Jan 2002 Posts: 3 | I don't know that much about a 60's model truck but i would check to see how differnt the Frount end under a 80's model c10 is. I just install a 85 c10 IFS in my 53 and had to throw away the monting stuff for it because i will not work with me from and frount end. I could be wrong but i was under the impression that the ifs didn't change that much. don't run out and buy one just check into it
brian
