0 members (),
54
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#25551 07/31/2003 11:39 PM | Joined: May 2002 Posts: 36 Junior Member | | Junior Member Joined: May 2002 Posts: 36 | Does any one know if a set of 3.55 gears out of a tork tube car rear end will fit the housing of my 1/2 ton pickup rear end? Or does it matter in years?
I've never been lost just confused for a month or two. 1950 & 1952 chev. 1998 Chev 4x4.
#25552 07/31/2003 11:56 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | If it's a 50 Chev 1/2 ton with torque tube like in your signature then yes.
54 3100 with 235 62 flatbed dump C60 with 261
#25553 08/01/2003 12:17 AM | Joined: May 2002 Posts: 36 Junior Member | | Junior Member Joined: May 2002 Posts: 36 | Thank you Tony, I have a chance to get a set out of a car to go into my 50 torque tube if it fits the price is right.
#25554 08/01/2003 7:49 AM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Geez, I never noticed you said car torque tube. I now doubt it will fit. I am surprised others didn't jump all over me. Guys?
#25555 08/01/2003 3:29 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Tony M, I just woke up. You know I would have been at the head of Owlybear's line grabbing at those gears if I thought they would fit.....
I don't know for sure but will be calling Patrick today and he'll shed some light.
Stay tuned.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#25556 08/01/2003 4:30 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Does anybody actually know the ring gear diameter and axle spline count of the different torque tube rear ends?
Chevy used two different ratios in their sedan torque tubes. The cars with 3 speed stick got 3.73s, and the cars with 'Glide got 3.55s. I simply found a set of Glide gears and swapped them in.
I have several 3.73 rings and pinions out of '54 sedans I parted. They may be rusty or mismatched, but if anybody wants to experiment, I'll send 'em for shipping and beer money.
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#25557 08/01/2003 5:55 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Just spoke with Patrick Dykes who confirms that the sedan 3:55 will not fit in the truck. His exact wording was "If they did fit, I wouldn't be offering these gears and kits".
#25558 08/01/2003 7:55 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | It could also mean: "If they did, would I tell you?"
#25559 08/02/2003 3:03 AM | Joined: May 2002 Posts: 36 Junior Member | | Junior Member Joined: May 2002 Posts: 36 | I have gears coming out of a power glide transmission will this make a big differance or not????
#25560 08/02/2003 3:27 AM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Yes, I believe that the Powerglide gears probably came out of a sedan and will not work in a truck.
#25561 08/02/2003 3:35 PM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Passenger car and pickups share the same pinion bearings but thats it.
See the USA in your vintage Chevrolet! My Blog | | |
#25562 08/02/2003 6:16 PM | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | Pass. car ring and pinion are much smaller than the truck gears. No way will they interchange. I do know someone that adapted the whole '50-'54 PG rear end and torque tube into a '40 1/2-ton though. | | |
