| | | Forums66 Topics128,034 Posts1,055,533 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#25406 02/06/2005 1:20 AM | Joined: Oct 2004 Posts: 26 Junior Member | | Junior Member Joined: Oct 2004 Posts: 26 | Just wondering. Is there anyway to match a SM420 tranny from a 66 C20 pickup to a bigblock chevy engine?? Will I just tear up the tranny or shell out my rear end? Or is it just not going to work?
I've heard a 6cyl flywheel will fit on a 350....will it bolt onto a big block & still work? Then I wouldn't have to change bellhousings & clutch stuff.
I know a guy who has a 366ci Chevy big block for sale and thought that would be great to put in my 66 Chev C20 pickup. We have them in grain trucks & they have great torque.
Any help is appreciated. | | |
#25407 02/06/2005 2:46 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The SM420 is a pretty tough transmission, but it was not designed for the kind of abuse a big block can hand out.
A friend of mine's dad ran a 396 in a early 60's 1-ton truck with an SM420 for years with no problems.
So my conclusion is that your success will depend a lot on how you drive it.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#25408 02/06/2005 4:08 AM | Joined: Oct 2004 Posts: 26 Junior Member | | Junior Member Joined: Oct 2004 Posts: 26 | Yea I won't be grinding gears or drag racing,but I might pull a trailer sometimes. Do you have any idea how to match everything up?
Anyone else had expiriece with this?? Thanks everyone. | | |
#25409 02/06/2005 4:14 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | The bigblock should bolt in fairly easily, with the exception of maybe an engine mount. Keeping the coolant temperatures down will be your main concern. Unless you load it heavy, I don't think your truck will get enough traction to tear anything up but the rear tires. I've got a built 454 in my 4X4 and never had damage to the drivetrain, except a u-joint got dry on me and made some noise. Scott | | |
#25410 02/06/2005 5:00 AM | Joined: Oct 2004 Posts: 26 Junior Member | | Junior Member Joined: Oct 2004 Posts: 26 | Hey 48bigtrucks, What did you have to do to match the tranny up to the big block? Did you use the SM420? What did you have for a radiator?? Thanks. | | |
#25411 02/06/2005 7:43 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I can't tell you how Scott built his, but the stock bellhousing in your '66 will bolt to the big block. A 454 is externally balanced, meaning you have to use the 454 flywheel for it, but the other big blocks are internally balanced, so your original flywheel should work.
The stock V-8 mounts for a '66 should mount the big block just fine. If its a six, know that the 230/250 mount differently than a 292. The mounts may be the same, but only need to be moved, but I'm not sure about that.
Years ago I ran a mildly modified 350 in a '70 4x4 Blazer. I drove like a kid in those days (probably because I was one) and broke the transfer case twice and destroyed the front drive shaft once.
I abused that truck a lot, and it would break...
