7 members (NJC, Gray_Ghost, GMCJammer51, Greg_H, 50Chevy3100, 1955 1 Series, 1 invisible),
74
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#25255 07/05/2004 5:16 PM | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | picked up a55 235 hydramatic eng last fall no smoke no knocks just took the eng as its going in a 52 one tonwith a 4 speed got it on the stand upside down to do rear seal. it was [censored] oil real good cause the seal spun in the rear main cap i suspect from setting a yr andhalf.anyway got a whole set of gaskets from kanter with the rope seal.have it soaking in a 20oz pepsibottle full of oil.ques is how far do i leave it above the block deckafter getting it in the seal bore?havnt done one of these babies since the early 70s. also all 4 mains are shimmed,the bearings look good this motor has never been apart inserts are stamped on the back with gm and a part#.the 4 door sedan it came out of only had 86 thousand on it and was being cut for parts for a sedan del resto.thanx in advance design for all replies steve sr  | | |
#25256 07/06/2004 7:07 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Fel-Pro recommends not soaking the oil seal before installation, saying it will tear. They claim you should just wipe the surface a bit with oil before you put the crank in.
