2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
#25221 03/27/2003 5:30 PM
Junior Member
Junior Member
I'm requesting advise on the best, easiest complete rear suspension swap for my 37 Chevy PU. I was told one swap would be from a S-10 4X4, not sure what year. I would like posi and around 3.50 gears, but I mainly want an easy swap for the complete rearend (hub to hub).
#25222 03/27/2003 6:57 PM
37 I have a 1938 1/2 ton panel delivery which has the same width dimensions I think as your pu. The rearend I used was from a 1988 S10 Blazer and has 3.73 gears and a posi. If you look on the site belwo there are some pictures. In Canada that setup at the wrecking yard was about $350. hub to hub. The only down side to this setup maybe the diameter of the brake drums. Depending on your setup.
John....38 Chevrolet Panel Delivery
http://community.webshots.com/user/tobytailford
