1 members (baldeagle),
91
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#25078 02/24/2002 4:19 AM | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | 250 6 cylinder; in salvage yard out of vehicle.
non-integral head; engine completely intact but uncovered; by visual inspection and gut feeling i'd say it's never been rebuilt.
has factory p/s pump and lines attached and factory a/c compressor; owner wants $200.
feedback? | | |
#25079 02/24/2002 4:25 AM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Water down carb throat? Valves open, let in water, one or two rusty cyl for sure? does it turn? P/steer and AC parts good find. Seems high to me, but I haven't bought a junk engine for some time, maybe that's what they get now adays. I wouldn't go more than $100 myself, depends on how "bad" you wanted it!  I always pay way too much for the stuff I want bad, think they can "read" my face or something. Course, when it's MY stuff,it's "junk" and not worth anything to the next guy!
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
#25080 02/24/2002 2:25 PM | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | GL I think I went about it the wrong way. I asked him about the p/s pump and accessories and he said 50 bucks; that's when I asked him about the entire unit. I should have worked it the exact opposite (engine price first, then p/s).
I think I might be able to work him to $175.
Valve cover is on and sealed tight. So there's probably been minimal water in the cylinders. the 1 bbl has the original carb cover assembly fully intact, with the opening tilting slightly downhill. So I doubt if much water has entered the head that way.
Would it be best to pop the oil pan off and see what's in it? Because wouldn't any water in the cyl. eventually make it's way to the pan?
Does a rusted cylinder (or cylinders) mean a trashed engine necessarily? | | |
#25081 02/24/2002 3:46 PM | Joined: Mar 2000 Posts: 10 New Guy | | New Guy Joined: Mar 2000 Posts: 10 | I've had success cleaning up rusted cylinders on tractors. You can see the damage more clearly from the top, but it is going to look much worse initially than it really is since there is going to be slop on top of the pistons.
From the bottom you'll see some rust on the rods if there is much water present. If you see rust on the lower part of the cylinder, work it with some WD40 to see if it cleans. If not the top part of the cylinder is going to be very bad.
If there is water in the pan, and you are rebuilding away, use it as a bargaining point.
But the real mechanics will know if you can bore the cylinders to get past pitting.
Larry Hayes Charlottesville, VA 48 3600 Flat Bed 49 6400 Grain Dump 48 Allis Chalmers G
#25082 02/24/2002 5:12 PM | | Anonymous Unregistered | | Anonymous Unregistered | I just picked up a complete 292 fan to flywheel, air cleaner to oil pan plus alternator, starter, motor mounts for $100. Has 100k miles on it, clean oil in the oil pan, stored in someone garage since removed from vehicle.
You should be able to try to turn it over to see if it is locked up or not. $200 seems high to me if it is potentially just a core. If any water in the oil, price drops in half. | | |
#25083 02/25/2002 1:06 AM | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | i heard someone on the local swap swap trying to give away a 292 sat,started to call but i want a v8. | | |
#25084 02/25/2002 4:19 AM | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | points WELL taken. I just need to exercise more patience. There seems to be a big shortage of that in my life lately Thanks guys! -ftyler | | |
#25085 02/25/2002 11:11 PM | Joined: Oct 2001 Posts: 36 Member | | Member Joined: Oct 2001 Posts: 36 | Only way I'd buy it any price was if the owner agreed in writing to take it back after the head was pulled. Bought one 235 engine that was supposedly covered at all times--HA! Had rained in carburetor--Numbers 3 & 4 pistons had to be removed with a sledge hammer--then all cylinders bored .060"--complete overhaul--many bucks--could have bought a completly rebuilt long block for what I ended up in it. Believe it or not, there are some people out there that will flat out LIE! | | |
