| | | Forums66 Topics128,282 Posts1,058,492 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#25041 10/29/2003 11:46 PM | Joined: Oct 2003 Posts: 14 New Guy | | New Guy Joined: Oct 2003 Posts: 14 | I HAVE A 1978 235 6 WITH AFTER MARKET MOTOR MOUNT SETUP IN MY 52 CHEVY CAN A 350 GO IN WITHOUT CHANGING MOTOR MOUNTS AND STOCK STEERING BOX | | |
#25042 10/30/2003 2:42 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | A 350 will not fit without moving the steering box if you have the original frame/suspension on these trucks. Motor mounts will need to be changed as the 6 and the V-8 are different. - Do you mean you have a 1978 230 six cylinder??? 235 engines were made up to 1962 (here in the U.S.)
#25043 10/30/2003 3:25 AM | Joined: Oct 2003 Posts: 6 Member | | Member Joined: Oct 2003 Posts: 6 | The 235 motor was still availible for a number of years after gm stoped putting it in cars/trucks , It was offered as a industrial lift truck motor . I have/had the recipt dated from 1972 (I think)for just such a motor but the casting number shows it as a 1962 , It also has higher compression for the use with propane. | | |
