Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Phak1, jmoore), 154 guests, and 3 robots.
Topics128,282
Posts1,058,493
Members48,490
#25041 10/29/2003 11:46 PM
I HAVE A 1978 235 6 WITH AFTER MARKET MOTOR MOUNT SETUP IN MY 52 CHEVY CAN A 350 GO IN WITHOUT CHANGING MOTOR MOUNTS AND STOCK STEERING BOX
#25042 10/30/2003 2:42 AM
A 350 will not fit without moving the steering box if you have the original frame/suspension on these trucks.
Motor mounts will need to be changed as the 6 and the V-8 are different.
Do you mean you have a 1978 230 six cylinder???
235 engines were made up to 1962 (here in the U.S.)
#25043 10/30/2003 3:25 AM
Q
Q Offline
The 235 motor was still availible for a number of years after gm stoped putting it in cars/trucks , It was offered as a industrial lift truck motor . I have/had the recipt dated from 1972 (I think)for just such a motor but the casting number shows it as a 1962 , It also has higher compression for the use with propane.
