0 members (),
80
0
Mod | | | Forums66 Topics128,050 Posts1,055,644 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#25010 10/22/2002 2:07 AM | Joined: Oct 2002 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 77 | NEED HELP. JUST INSTALLED 3.73 GEARS WHAT IS THE COLOR CODING FOR TRANNY SPEEDOMETER GEAR? OR DOES ANYONE KNOW ANY FORUMLA FOR FIGURING THIS OUT. | | |
#25011 10/22/2002 4:37 PM | Joined: Feb 2000 Posts: 5,199 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,199 | Was the speedometer correct before you changed rear gears? If it was you can figure out what gear to buy. If you had a 4.10 gear and changed to a 3.73, you decreased rpm by 10%. So now, pull out your current speedometer gear and decrease it 10%. If it wasn't correct before check out this link on speedometer ratio and testing. Joe H speedometer shop | | |
