7 members (fonz8261, jmoore, Hotrod Lincoln, Woodcmiami, Ludwig.van.dille, Shaffer's1950, 1 invisible), 73 guests, and 1 robot.
Topics128,077
Posts1,056,280
Members48,441
#2488 02/20/2004 3:11 PM
Hey Stovebolter's,
I have the opportunity to pick up a late eighties Caprice Classic. I have a 55 first series with a 68 camaro 283 small block and four speed borg warner transmission. I would like to use the rear end and up date my braking system. Can this be done with this type of vehicle. I am also looking a borrowing power steering parts as well.
Am I being realistic here? I want to update my truck and make it a little safer. Thoughts?
Chris
Chris 1955FirstSeries
Before you buy it, measure the rear end between the wheel mounting surfaces. I think you will find it is too wide. Most use a camaro or nova size for a donor.
Fred
52 3600
69 C-10
Check the wheel bolt pattern. Some big Chevys have the same larger five-bolt pattern as the big GM cars and pickups. Finding a disk brake conversion that would match could be a trick.
Great post, my friend has an 85(?) or so caprice classic as well. We were planning on stealing anything worth keeping for my 59' and anything any of our hot rob pals may need. Then off to the yard!!!!
Thanks for all the responses. I will definitely measure the rear end on the caprice and make sure the wheel bolt patterns match. If the caprice doesn't work for some reason what year class of camaro's would I look for?
Chris
Chris-
Check out this extensive page with tables of measurement info for rear end swaps, IFS and other driveline items.
Rear End Swap Info
Thanks 51PhatBoy,
I will definitely check it out. Sounds like I could get the Caprice for under $800 bucks.
chris55.1,
sounds like a winner chris, i don't know about the later years, but i installed a 1981 caprice 10 bolt on my 51'half ton, just fine i'm using 10x15 rally's, chevy blt. pattern. ground down the axle smooth and welded new pads and two inch high blocks for a little lower stance.
never bottoms out, used 69 camaro shocks to keep it level, nice set up no regrets. good luck. jake
I'm not sure I'd spend $800 for those parts. Unless the car has more than a rear axle and power steering for your project you might be able to spend your money better somewhere else.
Around here $100 to $150 will buy most any rear-end at a wrecking yard, and that should be enough to buy the complete IFS with power steering from one of the more common subframe donors.
I have the rear from under a '73 Chevelle under my 55 1st, and it fits real nice. I paid less than $100 for the complete car with a 350 and turbo 350.
The kits that put power steering on the original straight axle use the power steering box off a of 73-87 Chev pickup, not the one off a car like the Caprice.
I'd encourage you to look elsewhere unless this car has lots of parts you're willing to work hard to adapt.
#2497 02/20/2004 11:10 PM
"MONGO"
"MONGO"
Chris,
I picked up a 91 Caprice Classic cheap like that with hopes of useing it under my 51 extended cab. I've got an article somewhere about modifying perimeter frames from cars to use under old iron. If you want I could scan and email it to you if your thinking that route. The wheelbase front to back is pretty close but I'm not sure on the width. If your not gonna go that route there's ton's of parts you can scavenge off of it, is it a runner? If so It's prob. got a 305 (or 350 if it was a cop car) you can pull and use. I got mine cause a friend bought it on ebay to use the motor, tranny, and electronics for the EFI in his 72 1/2 ton, after that was done he didn't much care for the rest of the car so I got it cheap.
Mongo
Mongo's Garage
Vintage GM Truck's & Parts
https://mongosgarage.com
