6 members (UtahYork, KEVINSKI, MikeStone1953, Jay R, 1955 1 Series, crenwelge), 354 guests, and 5 robots.
Topics128,159
Posts1,057,027
Members48,460
Junior Member
Junior Member
Hey guys. I just had a good friend who is a mechanic take a listen to my engine. i ended up doing an oil change yeserday so that's fresh. I haven't done a valve check or re-adjust yet,..probably later tongiht. However, as we listened to it he told me right away that is was the water pump! he listened to it with a piece of metal rod and then did I and yeah, sounds terrible!!!
Soooo,..here's my question. Can i rebuild it? If so what's the best way (any tips/tricks, etc.??) and if its rebuildable where can i locate parts?? Thanks in advance as always! You guys have been a great help thus far with it!
Jason
"coal town kid"
Junior Member
Junior Member
Oh yeah and its a 1950 GMC 100 series pickup witha 228 6 cylinder engine,...
Riding in the Passing Lane
You could probably find the bearings by matching up the old ones but it would be hard to find the seals. You should be able to buy a reman for $25-35. smile
1972 Chevy c10 Cheyenne Super
H Online: Content
By the time you do all the things a rebuilder would, you'll spend at least 3 times the cost of a reman unit, and you won't get a warranty on your own work, either!
Do you have a press setup for removing the pulley? If not, try a local mom & pop parts store for a rebuild. If they don't have a rebuild, go to the links section and check with the on-line vendors.
Fred
52 3600
69 C-10
Junior Member
Junior Member
Ok,..so where would you say I would be able to score a good remanufactured water pump??
have you checked any auto parts stores? NAPA?
Junior Member
Junior Member
Not yet,....didn't think to.
Well if you buy a remaned pump I suggest you hold on to the old one until you have installed and run the new one for a few days or weeks. Heck the core charge maybe so small that you could just keep the old one.
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
Good advice Brian
I bought a brand new one from Chevy Duty a few weeks back for about $40. Might want to check them out.
Bodega Bob
http://www.submarinestore.com
Where's my tin foil hat?!?
