1 members (Hotrod Lincoln), 60 guests, and 0 robots.
Topics128,050
Posts1,055,641
#24945 01/13/2005 3:17 PM
Apprentice
Apprentice
I need help in determining what year rear ends will interhange with the 66 1/2 ton pickup. Will all years with the rear coil springs interchange?
#24946 01/13/2005 4:05 PM
Any rear up til 72 will bolt in. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#24947 01/13/2005 10:59 PM
Riding in the Passing Lane
I might add the 71-72 have 5 bolt wheels.
1972 Chevy c10 Cheyenne Super
#24948 01/14/2005 12:39 AM
Apprentice
Apprentice
Thank you for the help. The 71 or 72 might be the ticket. I have five lug disk hubs for the front.
#24949 01/14/2005 2:30 AM
Z
Z Offline
63-72 have trailing arm mounts in the right place.if you use a 63-64 rearend you will have to adapt the panard bar.the 71-72 rearends are 1.5" wider.
#24950 01/15/2005 2:45 AM
Junior Member
Junior Member
That wider business that zenish spoke of, don't let it scare you. Once the rearend is under the truck, it looks fine. You don't notice the width difference, as it's only 3/4 inch per side. Your front end is likely somewhat wider already due to your disc brake conversion.
Tender caretaker of antique tractors and old trucks.
