| | | Forums66 Topics128,053 Posts1,055,777 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#24945 01/13/2005 3:17 PM | Joined: Sep 2004 Posts: 17 Apprentice | | Apprentice Joined: Sep 2004 Posts: 17 | I need help in determining what year rear ends will interhange with the 66 1/2 ton pickup. Will all years with the rear coil springs interchange? | | |
#24946 01/13/2005 4:05 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Any rear up til 72 will bolt in. Brian | | |
#24947 01/13/2005 10:59 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I might add the 71-72 have 5 bolt wheels. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#24948 01/14/2005 12:39 AM | Joined: Sep 2004 Posts: 17 Apprentice | | Apprentice Joined: Sep 2004 Posts: 17 | Thank you for the help. The 71 or 72 might be the ticket. I have five lug disk hubs for the front. | | |
#24949 01/14/2005 2:30 AM | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | 63-72 have trailing arm mounts in the right place.if you use a 63-64 rearend you will have to adapt the panard bar.the 71-72 rearends are 1.5" wider. | | |
#24950 01/15/2005 2:45 AM | Joined: Jan 2005 Posts: 24 Junior Member | | Junior Member Joined: Jan 2005 Posts: 24 | That wider business that zenish spoke of, don't let it scare you. Once the rearend is under the truck, it looks fine. You don't notice the width difference, as it's only 3/4 inch per side. Your front end is likely somewhat wider already due to your disc brake conversion.
Tender caretaker of antique tractors and old trucks.
