| | | Forums66 Topics128,052 Posts1,055,727 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#24762 07/28/2002 4:28 PM | Joined: Sep 2001 Posts: 466 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 466 | Anyone using the Lokar Nostalgia Shifter. I found a Chevy 350 w/auto trans to put in my 55-1st. I like the look of the Nostalgia Shifter. Is it an easy installation? Buddy in AK | | |
#24763 07/28/2002 11:32 PM | Joined: Apr 2000 Posts: 58 Member | | Member Joined: Apr 2000 Posts: 58 | shouldn't be any different installing than their other shifters, the only difference is the stick. | | |
#24764 07/29/2002 3:19 AM | Joined: Feb 2000 Posts: 5,201 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,201 | I installed one in my 37'. It was pretty easy. I had to set it at the front of the mount they sent to clear the seat. I don't know if that had something to do with it or not, but I had to cut the Lokar lever that mounted on the transmission shifter shaft and make it longer. The shifter it self is all most on top of the shift shaft. This may be why the leverage was wrong. After that little problem, it worked out great. I even mounted the stock park brake lever to the right side shifter bracket. Its a little high, but carpet and a boot over the lever and you will never know. Joe | | |
