7 members (mick53, Tiny, Southerntruck, HandyAndy, TUTS 59, 2 invisible), 82 guests, and 2 robots.
Topics128,093
Posts1,056,046
Members48,433
#247415 08/16/2007 5:30 AM
looking at new steering and brakes .would like close to stock ride height and ifs.amc pacer? gm frame clip? mustang 11 ? pat
pf
#247416 09/23/2007 10:20 PM
What have you found?
1947.2 Chevy Panel Truck 1-ton
In Project Journals
In the DITY Gallery
1955.2 Chevy Suburban
1955.2 Chevy 6700 Bus/RV
#247417 09/24/2007 3:09 AM
I am installing 75 Camaro clip with disc brakes,setting height of clip to ride close to stock.
pf
#247418 09/24/2007 3:52 AM
1 Offline
do your homework! i would contact buffalo engineering in stanwood wa. because the ones he does they narrow the subframes 6". the rearend from the 75' camaro will work fine. too wide of track width in my opinion also if you set your ride height to low and need to raise it you run into alignment issues. going through this on a 50' 3100 with a 74' nova clip,350/350,74' nova rear. besides the alignment issues the rearend is too narrow. this truck was purchased by my cousin with all the mods already done. if i had been asked before the purchase my advice would be too pass on it. good luck on your project!
#247419 09/27/2007 12:34 PM
installing the clip is a test of my insanity, I do have stock spare frame if. pat PS working from tech tips on installing camaro clip
pf
