0 members (),
54
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 20 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 20 | looking at new steering and brakes .would like close to stock ride height and ifs.amc pacer? gm frame clip? mustang 11 ? pat
pf
| | | | | Joined: Nov 2005 Posts: 324 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 324 | | | | | | Joined: Jan 2007 Posts: 20 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 20 | I am installing 75 Camaro clip with disc brakes,setting height of clip to ride close to stock.
pf
| | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | do your homework! i would contact buffalo engineering in stanwood wa. because the ones he does they narrow the subframes 6". the rearend from the 75' camaro will work fine. too wide of track width in my opinion also if you set your ride height to low and need to raise it you run into alignment issues. going through this on a 50' 3100 with a 74' nova clip,350/350,74' nova rear. besides the alignment issues the rearend is too narrow. this truck was purchased by my cousin with all the mods already done. if i had been asked before the purchase my advice would be too pass on it. good luck on your project! | | | | | Joined: Jan 2007 Posts: 20 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 20 | installing the clip is a test of my insanity, I do have stock spare frame if. pat PS working from tech tips on installing camaro clip
pf
