0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 96 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 96 | Greetings to all, i have a '46 Carrtall that I am attempting to restore. I have the front axle off the vehicle and had to take it to a shop to get the spindle bolts out. The problem that we have encountered is the new bushings that come in the kit do not fit, they are too loose on the spindles. Even though they are snug on the axle. Is there anyplace to get various size bushings? the book just says that they are all the same? Anyone have this situaton before? How to remedy? Thanks in advance for any help, Richard
Richard J Patrick - 1946 Suburban
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | The kit you have may be for another vehicle, measure hole in the axle and post that info may get someone to measure their axle. Or, call Jim Carter's or another truck vendor for a measurement. Is you truck a half or 3/4 ton, may make a differance. | | |
