2 members (Chip O, Hotrod Lincoln), 140 guests, and 2 robots.
Topics128,135
Posts1,056,422
Members48,441
#247078 05/12/2007 10:19 PM
Does anyone know the original length of the cables for the clamshell tailgate on a TF Burb? I only have a few pieces of the originals left. The pieces I have- a piece with a ball on one end(for the tailgate side) and a ball with a small bracket to attach to the retractors. Are they one piece?
I am planning to have these custom made unless some one has them????
#247079 05/13/2007 8:54 PM
Apprentice
Apprentice
on my 50 suburban i bought the retractors and cable from Danchuk. i think i got the nomad retractors and cables . http://www.danchuk.com/03_06_tailgate_cable.html#200
http://www.danchuk.com/03_06_tailgate_cable_retrac.html
#247080 05/13/2007 9:40 PM
51 suburban I have a 49 w clamshell. Was the length of the cable the same for 50 versus the 55 listed above from Danchuk? Any modification needed for installation ?
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
#247081 05/14/2007 6:16 PM
Thanks for the replies.
I had heard that the cable lengths for the wagons and burbs were different. The burb had longer cables due to the length of the tailgate.
Do the cables have a stop on them to prevent the tailgate from opening too far?
#247082 05/15/2007 3:25 AM
If no one comes up with the answer, I will try an remember to measure them when I go to the property where I have them stored.
#247083 05/15/2007 1:20 PM
Thanks, that would be a great help!
Let me know,
Chuck
#247084 05/23/2007 1:12 AM
Apprentice
Apprentice
the length is the same . it fits perfect . i will post some pictures of cable later when i go back to the body shop were my suburban is at
#247085 05/23/2007 3:47 AM
According to a master parts book the part number for the cables was 3811539 and they were a fraction over 49 inches long for the burbs with the tailgate. They are longer than those used on the pickup. This was on the second ser. of trucks
#247086 05/23/2007 5:53 AM
what does the TF stand for as I see it used abit?
#247087 05/23/2007 6:55 AM
Task Force = 1955-59 series
#247088 05/24/2007 12:29 AM
Hubcycle,
your saying the AD and TF lengths are different? In your master parts book does the 3811539 number cross over to anything else that I can find a reproduction of?
Just so everyone is on the same page I'm talking about my TF(57 Burb).
#247089 05/27/2007 2:23 AM
Sorry, I have not replied sooner. Next time I get my hands on the book I will check for crossovers. The book I was using started with 55's TF trucks. I'am presently working on a 55 GMC Burb. I having a marine supply outfitter make me some out of coated 1/8 inch stainless cable. I'll let you know how they turn out and how much.
#247090 05/29/2007 3:31 PM
Sounds good!
#247091 05/29/2007 10:25 PM
firedriver: I happen to be in AutoZone today looking for a do-dad and seen quite a few different cables. When you find the correct length you may want to look at theirs before sending you $$ to someone else??
#247092 06/11/2007 8:51 PM
Sorry for the late response, I finally got up to the property to see the 1948/55 Suburban. I measured the existing cable and retractor length.
Cable: 44" overall length and 43 1/2" measured from inside the two lead balls. There is also another clevis type clamp, add 3/4"
Retractor: fully opened it is 48"
The cable can easily be made and there may be other cables out there that match. The ball is restricted in how far it can extend because of the support that it passes through.
