0 members (), 138 guests, and 3 robots.
Topics128,196
Posts1,057,391
Members48,471
I desperately need to replace my left rear fender but an unable to find a replacement either NOS or fiberglass. I was sold one about a year ago that is for a pickup. Guess what TOOOOO BIGGGG. can anyone be of assistance?
[email protected]
I'm not positive but give R&R Fberglass a call in Tenn. Richard Keller is the guy you want to talk to. phone 423-334-4455.
What years fit? I have a pair of rear steel panel fenders that I think are for a 1938 but not sure. They are diffidently for a pre 40. Maybe I can be of some assistance.
38 original
48 panel
59 stepside
46 in the back forty
Try these guys, I think they may only make fenders for the sedan delivery and the pick-up, but it's worth a try.
SUPERIOR
Highwayman: the 37-38 pickups are the same so I would imagine the panels are two. Maybe Bobber37 is checking around?
According to the Chevrolet Master Parts books the 1937-38 1/2, 3/4, 1 ton trucks rear fenders are the same for all the pickups and panels (54.25 inches long) p/n 594181 left and p/n 594182 right fits GC,GD,GE,HC,HD,HE except cab & chassis models. The 1.5 ton single units (non-dual wheel ) use p/n p/n594576 & 594855 rear fenders models SA & TA. The 1/2, 3/4 & 1 ton cab & chassis models use 594855 & 594855. The 1.5 ton dual wheel trucks use 595101 & 595102 and these fit 1937 to 1940 models SB,SD,TB,TD,VB,VD,,WA,WB. The 1.5 T dual wheel panels used 595467 & 595468.
34 & 35 trucks are the greatest
Fiberglass rear fenders for 1/2, 3/4 ton trucks are available from Jim Carter phone 816-833-1913 www.oldchevytrucks.comand also from the Filling Station www.fillingstation.com 541-258-2114.
Sorry it should be www.oldchevytrucks.com
35trucker: you may be right but I would have sworn that the panel fenders were not as wide????
35 trucker what are the demensions on the 1.5 ton?
I bought a fender the was perported to be for my truck but was too large. Its 58 1/2 inches long and 26 inches tall.
My 1/2 ton panel fender measures 55x23.5x7. these are approximate because fender is off truck
Group # 8.203, Part # 594181 & 594182 are the '37-'38 1/2 and 3/4-ton panel truck fenders. These are narrower than the PU fenders as they bolt into the wheelwell of the body like a car fender. Part of the wheel/tire is enclosed by the panel truck body. The fender bolts are installed "vertically" if you can picture that. These are specified for commercial "single unit" bodies. Single unit means panel, canopy express, and Suburban. Commercial means the lighter trucks, the larger 1-1/2 tons trucks are called utility trucks.
Group # 8.203, Part # 594855 & 594856 are '37-'38 1/2 and 3/4-ton PU rear fenders. These are wider than the panel truck fenders, as they have a flange to bolt "horizontally" to the box side. The wheel/tire is totally enclosed by the fender. These are specified for commercial cab and chassis bodies. That means a PU style truck with a cab and seperate box.
Both fenders will look the same on the outer 1/2 of the fender, the difference is in the inside 1/2 of the fender where they bolt to the body or box side.
The larger fender you have will look like the correct fender, except on steroids. It will be larger overall, and have a larger wheel opening for the 20" wheel and tires used on the larger trucks. This fender is worth much less than the same fender as a 1/2-ton would use. Many times the larger fenders are incorrectly advertised on ebay as fitting the smaller trucks, when in fact they don't as you found out. About the only way to learn the difference is to do what you did, and buy one and figure it out. I'm a slow learner, I made the same mistake more than once!
To be long remembered as he's cruising in
The Passing Lane
The set of panel fenders that I have are narrow and don't have the flange that would bolt to the box side. They bolt to the panel body on the top edge of the fender just like the 47-54 panel or burb.
38 original
48 panel
59 stepside
They are the same size fenders for 1/2, 3/4 tons just like the 33-36 rear fenders they just modify by cutting out the inside 1/2 in areas for clearance for the panels and punch new holes in the upper surface. If you have a pickup fender you can make a panel fender from it. The 1.5 ton fenders for all panels , cab & chassis, etc. are bigger and have the same type of cutouts and mounting between single unit and cab & chassis you can make the single units from the cab and chassis fenders.
I have the original Chevrolet Indianaoplis Commerical Body assembly blueprints for the 37-38 trucks and earliers models.
bobber37 Send me an e-mail with US post office address and I'll send you copies of the original Chevrolet prints of the rear fenders all drawn to the same scale for the 1/2 , 3/4 and 1.5 ton trucks.
Hey bobber37, I sent you an email.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
bobber37 did you get those truck prints I sent you? Did they help?
Sure did 35 Trucker. UYes thay did help alot. Thanks for your help
