3 members (TooMany2count, 32Fordpuchoptop, Hotrod Lincoln), 92 guests, and 3 robots.
Topics128,141
Posts1,056,485
Members48,441
#246895 03/18/2007 8:21 PM
Does anyone know if the gas tank for a '46 1/2 panel is interchangeable with a pickup?
I need a fuel filler neck and tank but don't have the dimensions or an old unit to match up.
Thank you
#246896 03/19/2007 4:12 AM
'39-'46 panel gas tank hangs off the frame rail, and the '39-'46 PU tank is under the seat. '47-'48 AD PU tank would be similar though, as they hung off the frame.
To be long remembered as he's cruising in
The Passing Lane
#246897 03/19/2007 1:34 PM
On my 46 1 Ton panel the tank is under the seat and looks just like the pick ups.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
#246898 03/21/2007 2:51 AM
Mine has the hole in the side for the filler neck and a spot under the frame for a tank so I don't believe it was under the seat
Thank you
#246899 03/24/2007 9:44 PM
I have a 46 1 ton panel like Mike E, and like his mine had the tank under the seat. I never did a side-by-side comparison, but I always thought it was identicle to the pickups of the day.
MV
46 Chev One Ton Panel - S10 Frame Project
"What if the Hokey-Pokey is REALLY what it's all about?" - J. Buffet
#246900 03/25/2007 6:00 PM
Truckasaurus - Please email me (address is in my profile) and I'll send you pics of a NOS '39-'46 1/2-ton panel gas tank I have. I believe I have them for both 1/2 and 3/4 ton, the 3/4 had a slightly larger capacity.
The Passing Lane
#246901 03/25/2007 11:56 PM
The tank for your '46 1/2-ton panel is Group #3.001, Part #3692398, and has a capacity of 15 gallons according to the Chevrolet Master Parts Catalog. I emailed you a pic of a NOS one so you can see what it looks like. It hangs from the right frame rail on brackets that are riveted to the frame and is held on by metal band straps. The '47-'48 PU and AD panel gas tank is very similar, but slightly larger at 16 gallons. One of the later tanks might be easier to find and not too hard to adapt, as the '37-'46 1/2-ton panel tank will be tough to find in good shape I'll bet.
The Passing Lane
