| | | Forums66 Topics128,114 Posts1,056,287 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 90 'Bolter | | 'Bolter Joined: Oct 2005 Posts: 90 | Does anyone know if the gas tank for a '46 1/2 panel is interchangeable with a pickup? I need a fuel filler neck and tank but don't have the dimensions or an old unit to match up.
Thank you | | | | | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | '39-'46 panel gas tank hangs off the frame rail, and the '39-'46 PU tank is under the seat. '47-'48 AD PU tank would be similar though, as they hung off the frame. | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | On my 46 1 Ton panel the tank is under the seat and looks just like the pick ups.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Oct 2005 Posts: 90 'Bolter | | 'Bolter Joined: Oct 2005 Posts: 90 | Mine has the hole in the side for the filler neck and a spot under the frame for a tank so I don't believe it was under the seat
Thank you | | | | | Joined: May 2005 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 145 | I have a 46 1 ton panel like Mike E, and like his mine had the tank under the seat. I never did a side-by-side comparison, but I always thought it was identicle to the pickups of the day. MV | | | | | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | Truckasaurus - Please email me (address is in my profile) and I'll send you pics of a NOS '39-'46 1/2-ton panel gas tank I have. I believe I have them for both 1/2 and 3/4 ton, the 3/4 had a slightly larger capacity. | | | | | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | The tank for your '46 1/2-ton panel is Group #3.001, Part #3692398, and has a capacity of 15 gallons according to the Chevrolet Master Parts Catalog. I emailed you a pic of a NOS one so you can see what it looks like. It hangs from the right frame rail on brackets that are riveted to the frame and is held on by metal band straps. The '47-'48 PU and AD panel gas tank is very similar, but slightly larger at 16 gallons. One of the later tanks might be easier to find and not too hard to adapt, as the '37-'46 1/2-ton panel tank will be tough to find in good shape I'll bet. | | |
