2 members (Hush, Forty9),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2003 Posts: 67 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 67 | Hi All,
I have a '51 GMC panel, with vent windows. I also have a 47 1/2 parts truck with one piece windows.
Is it possible to remove the 'guts' from the doors of each to convert my 51 panel doors to one piece windows ?
A door swap isn't a good option in this case.
Royzell | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I understand its a lot of work, but can be done.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Mar 2005 Posts: 25 Member | | Member Joined: Mar 2005 Posts: 25 | It will be less work and trouble to just change the complete door out. | | | | | Joined: Nov 2006 Posts: 87 Member | | Member Joined: Nov 2006 Posts: 87 | I read an article in my Custom Classic Trucks magazine recently that told how to do that on newer models. I will see if I can find it.
Toxictiki
'59 Apache 3100 panel (235) '51 Chevy Fleetline Deluxe (216) '48 Binder KB-1 (flathead 6) '77 Cadillac DeVille (425 donor)
"Once I was 'Chairman of the Bored' then I bought a Stovebolt."
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Look up "alltruckedup" Tony and Email him. He is also a regular on the GMC site. He has done this conversion. You have the best of both worlds here in that you have both sets of doors. It should be easy to see what needs to be done. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | The window regulators are different for one thing. However I believe the regulators both mount the same way with 3 screws but I could have forgotten, its been a while. The later regulator is shorter because the glass is not as long. There is a difference in the sheet metal on the door as well. For instance there is a notch on the later door for the vent window rear frame as well as on the window trim. It can be done but if I were to do it I'd want to swap out doors. | | | | | Joined: Apr 2003 Posts: 67 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 67 |
Royzell | | | | | Joined: Apr 2003 Posts: 67 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 67 | 'Couldn't find 'alltruckedup'
toxictiki - if you find the article you mentioned let me know.
Thanks all
Royzell | | | | | Joined: Feb 2001 Posts: 80 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2001 Posts: 80 | royzell Tony's email is [email protected] Ming the Merciless is his latest alias. | | | | | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Hey,here I am.I did the swap once because I had a 51 that needed a door and I had a nice 50 door. A few holes need to be drilled for the different 50 window regulator,a small notch needs to be cut to clear the vent window arm.And maybe a bracket needs to fabbed up,it was 10 years ago,the small details are a little foggy.Anyways,it was easy to do with common hand tools ,just compare doors to see what needs to be done. | | | | | Joined: Apr 2003 Posts: 67 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 67 | Thanks Guys, I like the look and fewer seals etc. of the one piece window.
I'll just have to do some pulling and have a look-see when the weather improves.
Royzell | | |
