| | | Forums66 Topics128,281 Posts1,058,471 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | I've got a '62 Suburban, with a full-width rear seat. The seat came with ONE original fastener set, the others were all lost. It's pretty basic; carriage bolts, wing nuts and lock washers. What isn't basic is the little block that goes between the wing nut and the tubing of the seat frame. I'll have zero problem reproducing these. However, I'm interested if anyone knows what these blocks are made of. After coming back from the sand blaster, the block looks bright and brassy. It isn't steel. Anyone know why they would have made them from brass, rather than steel? Is it actually brass?
The hardware looks just like what someone else posted in another thread, from their AD Suburban, so it doesn't look like they changed it a whole lot over the years. Anyone know if that is in fact the case? Does anyone else need any of these while I'm making mine?
-Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Brad, I welded a bent flat washer to a reg. flat washer for mine. It works but is pretty ugly & my fab skills run more toward function than form. I really don't like the looks of them but mine came w/none to use for a pattern, I only had a drawing from the assembly manual. Maybe it is some sort of bronze or brass? I could use some that look better. Brian | | | | | Joined: Apr 2004 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 72 | It so happens I was talkkin with a couple of truck buddies about these last night. I may be in terested in some of these for my 52 Burb. How are you gonna make these? I am curiuos? I was gonna use steel tube and slice it off to the same thickness and drill a hole. Then do any fine touch up work and paint. You can use elevator bolts from the hardware store and the wing nuts too.
52 GMC Suburban...52 Chevy 3/4 ton...49 CHevy 1/2 ton Rod...49 GMC 1/2 ton retro rod project
