1 members (CuzzFuzz), 83 guests, and 2 robots.
Topics128,135
Posts1,056,423
Members48,441
#246645 01/23/2007 3:10 AM
Apprentice
Apprentice
Hi guys, been awhile since Ive been here. Hey, Im needen a set of tires for my 52. Now Ive got the stock 16" [non split] rims. Heres my question. Do any of you kind folks know of any tall,narrow radial tires [the brand & size] that would run me, say in the $400-$500 range,mounted??? Ive looked a lot in old tire post on here & havent found any. Im in L.A. Cal. Thanks for ANY info you can lay on me. Jeff
#246646 01/23/2007 3:31 AM
Do you have a Cooper dealer nearby? They have narrow and tall LT radials that fit the rims. As far as sizes, do a search on "radial" and you will get a good idea what people are using.
#246647 01/23/2007 3:43 AM
You might try the White Wall Candy Store.
http://www.whitewalltires.com/
Toxictiki
'59 Apache 3100 panel (235)
'51 Chevy Fleetline Deluxe (216)
'48 Binder KB-1 (flathead 6)
'77 Cadillac DeVille (425 donor)
"Once I was 'Chairman of the Bored' then I bought a Stovebolt."
#246648 01/23/2007 3:53 AM
Jeff...I've put 215/75/16 Goodyear Wrangler blackwalls on my '49 Burb...they look great. Bought them on ebay...almost brand new for less than $300. delivered.
Steve G.
1942 Chevrolet 1/2-Ton Pickup Truck
#246649 01/23/2007 3:59 AM
Apprentice
Apprentice
Hey thanks for gettin back to me so fast guys! Ive checked w/ cooper before, YIKES! pricey Also checked out the whitewalltires.com Again Yikkes!! As I said I have about a 4-$500 budget. Now, I know its do-able[is that right??] I just dont know the exact ones guys use that "look the part" w/out costing me an arm. Thanks again for the info. Jeff
#246650 01/23/2007 4:57 AM
Jeff,
Cooper not Coker.
My Cooper LT radial tires (blackwall, like the originals) were mounted and balanced, with new tubes and plastic stem protectors, for less than $500.
Tim
#246651 01/23/2007 5:00 AM
Apprentice
Apprentice
oh,ok Tim, thanks! I will start checkin on them. Jeff
#246652 01/23/2007 5:39 AM
Apprentice
Apprentice
OK, I think this will work [depending on $$] A Cooper SRM II [2] Radial LT. Is that what you have Tim?? I think model # lt215/85R16 I know I'm bein a bit anal here but besides looks & $$ I am thinking of the clearance issue. Thank you again for all your info! Jeff
#246653 01/23/2007 1:08 PM
Jeff,
I did a search on "radial" in the general forum and found this (exactly what you found):
Cooper 4 ply SRM II
LT215/85R16 (with tubes, on original 16" rims)
Other manufacturers should also have a similar LT radial. Usually it is not on display but it is in a sales brochure or in their on-line listings. The brochures and on-line listings usually give dimensional information.
As I recall, the original tires had a loaded diameter of between 28-29 iches. I think that Cooper radial was supposed to have a loaded diameter of about 31 inches but on my rims the diameter is a little larger (maybe due to narrow rims). The larger diameter results in lower rpm.
Good luck,
Tim
#246654 01/26/2007 10:51 PM
Apprentice
Apprentice
Hey guys, just wanted to thank you all for help. Tim, thank you for all your input. "babys got some new shoes now"!Went w/an offshoot of Firestone brand called WHEEL TRAC Went w/some tall 31" pretty narrow suckers. They look/feel great! What a dif. from bias tires! Whole thing was just under $500 w/balancing bla bla. Thanks again guys!! Jeff
