| | | Forums66 Topics128,139 Posts1,056,455 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 22 Apprentice | | Apprentice Joined: Apr 2006 Posts: 22 | Hi guys, been awhile since Ive been here. Hey, Im needen a set of tires for my 52. Now Ive got the stock 16" [non split] rims. Heres my question. Do any of you kind folks know of any tall,narrow radial tires [the brand & size] that would run me, say in the $400-$500 range,mounted??? Ive looked a lot in old tire post on here & havent found any. Im in L.A. Cal. Thanks for ANY info you can lay on me. Jeff | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Do you have a Cooper dealer nearby? They have narrow and tall LT radials that fit the rims. As far as sizes, do a search on "radial" and you will get a good idea what people are using. | | | | | Joined: Nov 2006 Posts: 87 Member | | Member Joined: Nov 2006 Posts: 87 | You might try the White Wall Candy Store. http://www.whitewalltires.com/
Toxictiki
'59 Apache 3100 panel (235) '51 Chevy Fleetline Deluxe (216) '48 Binder KB-1 (flathead 6) '77 Cadillac DeVille (425 donor)
"Once I was 'Chairman of the Bored' then I bought a Stovebolt."
| | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | Jeff...I've put 215/75/16 Goodyear Wrangler blackwalls on my '49 Burb...they look great. Bought them on ebay...almost brand new for less than $300. delivered. | | | | | Joined: Apr 2006 Posts: 22 Apprentice | | Apprentice Joined: Apr 2006 Posts: 22 | Hey thanks for gettin back to me so fast guys! Ive checked w/ cooper before, YIKES! pricey Also checked out the whitewalltires.com Again Yikkes!! As I said I have about a 4-$500 budget. Now, I know its do-able[is that right??] I just dont know the exact ones guys use that "look the part" w/out costing me an arm. Thanks again for the info. Jeff | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Jeff,
Cooper not Coker.
My Cooper LT radial tires (blackwall, like the originals) were mounted and balanced, with new tubes and plastic stem protectors, for less than $500.
Tim | | | | | Joined: Apr 2006 Posts: 22 Apprentice | | Apprentice Joined: Apr 2006 Posts: 22 | oh,ok Tim, thanks! I will start checkin on them. Jeff | | | | | Joined: Apr 2006 Posts: 22 Apprentice | | Apprentice Joined: Apr 2006 Posts: 22 | OK, I think this will work [depending on $$] A Cooper SRM II [2] Radial LT. Is that what you have Tim?? I think model # lt215/85R16 I know I'm bein a bit anal here but besides looks & $$ I am thinking of the clearance issue. Thank you again for all your info! Jeff | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Jeff,
I did a search on "radial" in the general forum and found this (exactly what you found):
Cooper 4 ply SRM II LT215/85R16 (with tubes, on original 16" rims)
Other manufacturers should also have a similar LT radial. Usually it is not on display but it is in a sales brochure or in their on-line listings. The brochures and on-line listings usually give dimensional information.
As I recall, the original tires had a loaded diameter of between 28-29 iches. I think that Cooper radial was supposed to have a loaded diameter of about 31 inches but on my rims the diameter is a little larger (maybe due to narrow rims). The larger diameter results in lower rpm.
Good luck,
Tim | | | | | Joined: Apr 2006 Posts: 22 Apprentice | | Apprentice Joined: Apr 2006 Posts: 22 | Hey guys, just wanted to thank you all for help. Tim, thank you for all your input. "babys got some new shoes now"!Went w/an offshoot of Firestone brand called WHEEL TRAC Went w/some tall 31" pretty narrow suckers. They look/feel great! What a dif. from bias tires! Whole thing was just under $500 w/balancing bla bla. Thanks again guys!! Jeff | | |
