| | | Forums66 Topics128,132 Posts1,056,376 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#24649 09/18/2002 6:41 AM | Joined: Sep 2002 Posts: 2 Junior Member | | Junior Member Joined: Sep 2002 Posts: 2 | I have two SBC cams and somewhere along the line info on these was lost. Can anyone help me identify these cams? Whether they are factory or not I am not sure. 3863454, 965289 (F256). Thanks in advance. | | |
#24650 09/18/2002 9:41 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Do you know which brands these cams are? I would call some place like Crane,Comp Cams or Lunati and see if they can help you identify them Here is a place that could be interesting,, http://www.camtechniques.com/
#24651 09/18/2002 6:23 PM | Joined: Jan 2000 Posts: 206 Member | | Member Joined: Jan 2000 Posts: 206 | I can offer an enthusiastic personal thumbs up for Cam Tehniques. Owner David Generous has forgotten more about cam design than most of us will ever know. He has profiled several cams for me on his "Cam Doctor" and can grind just about anything you want. He is extremely patient and helpful, turns around work very quickly, and is a pleasure to work with. I would recommend Cam Techniques without reservation. | | |
#24652 09/18/2002 8:51 PM | Joined: Nov 2001 Posts: 58 Member | | Member Joined: Nov 2001 Posts: 58 | ChopTop, my advice is if they are out of the engine. Take them into a local cam grinder or parts shop they can give you proper spec.'s on the profile and duration etc. also tell you if they are worth regrinding or just paperweights. It's tough to find those old Chevy part numbers. | | |
