3 members (Brian Moore, klhansen, wilbur53), 100 guests, and 2 robots.
Topics128,126
Posts1,056,356
Members48,441
#24649 09/18/2002 6:41 AM
Junior Member
Junior Member
I have two SBC cams and somewhere along the line info on these was lost. Can anyone help me identify these cams? Whether they are factory or not I am not sure. 3863454, 965289 (F256). Thanks in advance.
#24650 09/18/2002 9:41 AM
Do you know which brands these cams are?
I would call some place like Crane,Comp Cams or Lunati and see if they can help you identify them
Here is a place that could be interesting,,
http://www.camtechniques.com/
#24651 09/18/2002 6:23 PM
I can offer an enthusiastic personal thumbs up for Cam Tehniques. Owner David Generous has forgotten more about cam design than most of us will ever know. He has profiled several cams for me on his "Cam Doctor" and can grind just about anything you want. He is extremely patient and helpful, turns around work very quickly, and is a pleasure to work with. I would recommend Cam Techniques without reservation.
#24652 09/18/2002 8:51 PM
ChopTop, my advice is if they are out of the engine. Take them into a local cam grinder or parts shop they can give you proper spec.'s on the profile and duration etc. also tell you if they are worth regrinding or just paperweights. It's tough to find those old Chevy part numbers.
John....38 Chevrolet Panel Delivery
http://community.webshots.com/user/tobytailford
