| | | Forums66 Topics128,164 Posts1,057,079 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 87 Member | | Member Joined: Nov 2006 Posts: 87 | Does anyone have a source to buy brake line fittings? I have a '59 Apache 31 panel and have been laughed out of several parts stores and one Chevy dealer when I showed them the fittings I was looking for. They told me that no such thing exists. I know I took it off of my truck, so I don't know what the problem is. I am replacing the entire brake system, so I really need the new fittings (connectors) to complete it. Can anyone help me? Thanks....
Toxictiki
'59 Apache 3100 panel (235) '51 Chevy Fleetline Deluxe (216) '48 Binder KB-1 (flathead 6) '77 Cadillac DeVille (425 donor)
"Once I was 'Chairman of the Bored' then I bought a Stovebolt."
| | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | Are you doing a restoration and want authentic fittings? If not and you are replacing all lines go with the newer type fitting from any NAPCO,JEGS, Etc.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
| | | | | Joined: Nov 2006 Posts: 87 Member | | Member Joined: Nov 2006 Posts: 87 | I'm not going with a restoration. I just want brakes that I know will stop me. Thanks for the info.
Toxictiki
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | Are you looking for any of these near the bottom of the page? Jim Carter catalog 55-66 | | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | I just redid my vacuum and brake lines. I got all the parts from Napa here locally. Jimmie D. | | | | | Joined: Jul 2006 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 53 | or carquest. not a napa fan here. | | | | | Joined: Nov 2006 Posts: 87 Member | | Member Joined: Nov 2006 Posts: 87 | Thanks guys - I ended up ordering the fittings that I needed from Jim Carter. They were the only parts that I could not find at the local auto parts stores. I tried Carquest, NAPA, Autozone and O'Reilly's and none of them had the fittings. It looks like Jim Carter has just about anything a guy could want. Thanks again....
Toxictiki
