1 members (Hotrod Lincoln), 327 guests, and 3 robots.
Topics128,169
Posts1,057,102
Members48,463
Does anyone have a source to buy brake line fittings? I have a '59 Apache 31 panel and have been laughed out of several parts stores and one Chevy dealer when I showed them the fittings I was looking for. They told me that no such thing exists. I know I took it off of my truck, so I don't know what the problem is. I am replacing the entire brake system, so I really need the new fittings (connectors) to complete it. Can anyone help me? Thanks....
Toxictiki
'59 Apache 3100 panel (235)
'51 Chevy Fleetline Deluxe (216)
'48 Binder KB-1 (flathead 6)
'77 Cadillac DeVille (425 donor)
"Once I was 'Chairman of the Bored' then I bought a Stovebolt."
Are you doing a restoration and want authentic fittings? If not and you are replacing all lines go with the newer type fitting from any NAPCO,JEGS, Etc.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
I'm not going with a restoration. I just want brakes that I know will stop me. Thanks for the info.
Toxictiki
Anonymous
Unregistered
Anonymous
Unregistered
Are you looking for any of these near the bottom of the page? Jim Carter catalog 55-66
I just redid my vacuum and brake lines. I got all the parts from Napa here locally. Jimmie D.
or carquest. not a napa fan here.
Thanks guys - I ended up ordering the fittings that I needed from Jim Carter. They were the only parts that I could not find at the local auto parts stores. I tried Carquest, NAPA, Autozone and O'Reilly's and none of them had the fittings. It looks like Jim Carter has just about anything a guy could want. Thanks again....
Toxictiki
