Kook what dusty said is right , my 40 was worn not as bad, what they are called is spring seats, and after you get the spring u bolts off there are two screws that hold the seat to the axle, there should be a slight drag to them when fitted together, there is a grease zerk on each one to lube them, after years of no grease it eats up the axle housing, this guy has a severe case if it leaks rear end lube out at spring perches, time for a new tork tube rear end, the idea I guess is these seats allow the axle to move up and down with putting twist on the springs, and the key way keeps the axle from slidding left or right from under the truck., I welded 20 gage steel on mine to take up the slack, but am look for a new rear tork tube that isn't as worn on the axle perches, what I got will do for now, but will feel better if I know the first bumb I hit the axle outer housing isn't going to break. good luck
jbennett
40 burb
