| | | Forums66 Topics128,151 Posts1,057,003 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#24578 05/24/2004 6:20 PM | Joined: Feb 2001 Posts: 81 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 81 | I have a 62 1/2 ton chevy with a 235 six. The clutch slave cylinder is adjustable. I have tried bleeding the cylinder and adjustin it back and forth on the shaft but still have difficulty shifting the three on the tree trans without "scratching gears". Any advice? The trans is a three speed Muncie with overdrive. Had the same problem with the previous three speed trans so don't think it is the trans. Thanks for any help!
Green Machine
#24579 05/24/2004 9:52 PM | Joined: Feb 2004 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2004 Posts: 110 | If you have adjusted the slave cylinder to the shortest travel and it still doesn't put the clutch into free wheeling position, the rod from the slave cylinder should have adjustment, if not then the rod may be worn on the ends and could be too short, or maybe you could check and see if the rod to the master cylinder has an adjustment (I don't think so) and the master cylinder piston isn't being pushed far enough.
Truck Tinker | | |
#24580 05/25/2004 12:48 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Do you have the right size throwout bearing?
