1 members (baldeagle),
107
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | Dummy that I am when I took the body off the frame I didn't make any sketches or take pictures of the points where the body attaches to the frame. I bought a new body mount kit from Jim Carter. It has 4 wood blocks and a number of rubber pads along with two 1/2 inch hex bolts and 8 3/8 inch carriage bolts about 6 inches long.
I looked in my reprint maintenance manual but it only gives info on the pickup cab, nothing on the sub body.
Can anyone out there direct me to a diagram or a manual that shows how to mount a sub body to the frame, where the wood blocks go etc. Need help as usual. Thanks Weeds | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Weds,
What is the part number of the Suburban body mount kit that you bought from JC? The pickup bed-blocks are different from the Suburban body blocks.
Also, I do not know if the Suburban blocks are the same for all A-D years.
I will post photos on Thursday. There are thin plates on the frame for mounting the Suburban blocks (special nails were used originally but I used very small diameter stainless wood screws). Two screws per wood block - they clear the block but screw into the metal plates.
Did you keep any of your old blocks?
Tim | | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | Tim,
The Jim Carter invoice says--
1 CBK156 Cab Mount Kit 47/551st, Panel/ Suburban/ Canopy 1/2 ton Kit complete with specialized bushings, washers, bolts,blocks.
It appears that I have the correct kit. Now if I only knew what to do with it. I have saved some of the old blocks. Thanks for the help.
Weeds | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | Okay, sorry this took so long. Had to wait for daylight to crawl under the body. ( And after the kids were fed, etc.) Starting at the rear. Rubber pads and carriage bolts. Mount just behind the axle hump, blocks, rubber pads ( between the frame and block ) and carriage bolt. Mount just in front of the hump, block, rubber pad and carriage bolt. Mount behind the door, rubber pad and carriage bolt. Mount at the very front, rubber pad and cap screw ( hex bolt.) You don't have anymore then 10 pads, do you?? You can also get the offset washers for underneath the carriage bolt heads. Looks like Chevy Duty has them in zinc, stainless and polished, although I think the plywood takes the cup type and the Chevy Duty ones look flat. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | MNSmith has posted the answer. I will not post pictures, unless you want them. | | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | Hey MN Smith, Thanks for crawling under your sub to answer my questions. I think my bolt kit is the correct one. I appreciate your efforts. It amazes me that fellow bolters go to so much trouble to answer my questions. Again thanks.
Tim, If you already have the pictures I would like to see them. Don't take pictures if you don't already have them.
Weeds | | | | | Joined: Mar 2005 Posts: 267 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 267 | weeds let us know how it goes. i was looking at that same kit and was curious if it was any good. was it in stock. i have not dealt with carters in while and was thumbing thru their catalog just before i found this post. great timing i believe. i too am amazed at the people here .it's cool to hang around here with these folks
I don't suffer from insanity, I enjoy every minute of it!
| | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | TPYLE I am going to dry fit the body on the frame next week and I will let you know how it goes. I believe Jim Carter had the sub body mount kit in stock because I received it only a couple of days after I ordered it.
Weeds | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Weeds, Here is a photo album of Suburban body mounts. It includes photos "from below" of all mounts except the front cab mount (which is the same as on a pickup - a recessed metal "cup" on the top of the body and a pad between the body and frame). I will post another album tomorrow in the headliner thread that you started. Sorry about the delay - I'm taking photos while I'm under the suburban removing transmission, clutch assembly, and flywheel (to have the flywheel resurfaced and balanced). Tim | | | | | Joined: Mar 2005 Posts: 267 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 267 |
| | | | | Joined: Mar 2004 Posts: 44 Member | | Member Joined: Mar 2004 Posts: 44 | 1954 Chevy 3100 Panel Truck 2004 GMC Yukon 2002 Chevy 1500 4X4 "Those who expect to reap the blessings of freedom, must, like men, undergo the fatigues of supporting it." Thomas Paine, The American Crisis, No. 4, September 11, 1777
| | | | | Joined: May 2002 Posts: 144 Shop Shark | | Shop Shark Joined: May 2002 Posts: 144 | Dear Tim: Hey... those are great photos, and say more than a thousand words each!! I have been looking at old 'burbs and panels but the only ones I have been able to see were so rusted or repaired (read patched!) I couldn't tell what was suposed to be. Thanks again Ter | | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | Tim, You saved my life! Fantastic pics. My body is going on the frame next week so I can fit up the steering, floor pedals, gas tank filler etc, etc. Thanks so much! Weeds | | |
