7 members (Peggy M, Hambone, 68ironhead, 2-Ton, TUTS 59, DaveV, msmall),
54
Mod | | | Forums66 Topics128,009 Posts1,055,296 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 70 Member | | Member Joined: Feb 2006 Posts: 70 | will a 62 suburban fit on a 92 blazer frame
bill
| | | | | Joined: Apr 2006 Posts: 159 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 159 | Are the wheel bases close to the same ? If they are you could probobly revamp the body mounts to work ? i assume these are both 2 wd .
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
| | | | | Joined: Feb 2006 Posts: 70 Member | | Member Joined: Feb 2006 Posts: 70 | i was going from 2 wheel to 4wheel but i think the blazer is to short
bill
| | | | | Joined: Jan 2002 Posts: 244 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 244 | You'll need to measure from the center of the front wheel to the center of the rear wheel on both vehicle then see how close the measurements are.
I mounted my '56 Burb on a '00 GMC Sierra chassis but had to move the rear axle forward about 3 inches. The width allows me to tuck the rear wheels under but have to use narrower tires. | | | | | Joined: Apr 2006 Posts: 159 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 159 | Seon did you use the FI motor,4L60 trans,a/c , etc ? If not more details please sounds cool.How about a pic ? Bill this sounds interesting .
| | | | | Joined: Jan 2002 Posts: 244 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 244 | Yep, I used everything I could from the donor truck...steering column, gas tank, exhaust, master cylinder, swing brake pedal...everything I've posted several pics so do a search to view. | | |
