You'll need to measure from the center of the front wheel to the center of the rear wheel on both vehicle then see how close the measurements are.
I mounted my '56 Burb on a '00 GMC Sierra chassis but had to move the rear axle forward about 3 inches. The width allows me to tuck the rear wheels under but have to use narrower tires.
Yep, I used everything I could from the donor truck...steering column, gas tank, exhaust, master cylinder, swing brake pedal...everything I've posted several pics so do a search to view.
