Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 44 guests, and 4 robots.
Topics128,009
Posts1,055,293
Members48,419
#245441 04/03/2006 9:13 PM
will a 62 suburban fit on a 92 blazer frame
bill
#245442 04/07/2006 2:23 AM
Are the wheel bases close to the same ? If they are you could probobly revamp the body mounts to work ? i assume these are both 2 wd .
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
#245443 04/07/2006 12:13 PM
i was going from 2 wheel to 4wheel but i think the blazer is to short
bill
#245444 04/07/2006 1:51 PM
You'll need to measure from the center of the front wheel to the center of the rear wheel on both vehicle then see how close the measurements are.
I mounted my '56 Burb on a '00 GMC Sierra chassis but had to move the rear axle forward about 3 inches. The width allows me to tuck the rear wheels under but have to use narrower tires.
#245445 04/11/2006 1:36 AM
Seon did you use the FI motor,4L60 trans,a/c , etc ? If not more details please sounds cool.How about a pic ? Bill this sounds interesting .
#245446 04/11/2006 1:57 AM
Yep, I used everything I could from the donor truck...steering column, gas tank, exhaust, master cylinder, swing brake pedal...everything wink
I've posted several pics so do a search to view.
