0 members (), 132 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#245158 01/15/2006 2:57 AM
Who carries 60-66 burb/panel body mounts or do I hafta make some. brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#245159 01/15/2006 4:05 AM
anything like the pu cab mounts? alla suppliers have the hardware for those , and if its anything like the TF panel mounts, it's pretty simple to use the pu parts and bolts from the hardware store
#245160 01/15/2006 5:07 AM
nahh red, they are different, they are rectangular & quite a bit thinner than truck mounts. I have some thick rubber that looks close, just not sure how thick they are sposed to be, they are kinda squashed after 40 yrs. brian
#245161 01/15/2006 5:16 AM
I just looked through my new Chevs Of The 40's catalog and coulda sworn they had some listed in there!
#245162 01/15/2006 9:33 PM
Maybe Steele Rubber would have them?
1954 GMC De Luxe COE
#245163 01/15/2006 11:41 PM
Yup! www.chevsofthe40s.com Part #3685018A 47-54 panel or suburban. (09.009-4) $24.00 a set.
#245164 01/16/2006 12:46 AM
Sorry Mnsmith but mine is a 64, Jim Carter shows them for task force 55-9. brian
#245165 01/16/2006 3:08 AM
Doh! My bad! Should've read your original post a little better! I hope you find what you are looking for!!
#245166 01/18/2006 10:18 PM
V
V Offline
If you can't find them there are places on the web that will rebuild your stock mounts with new rubber. Don't have a specific link, but I have run across them before.
#245167 01/19/2006 1:17 AM
Z
Z Offline
steel rubber products rebuilds rubber parts.
#245168 01/19/2006 4:16 AM
they look like rectangular rubber pads, really basic & simple. If I knew the correct thickness I could cut some out I spose. Energy suspension lists them for 67-72, I wonder if they are close to 60-66 parts. brian
