2 members (Gdads51, 55shaker),
166
0
Mod | | | Forums66 Topics128,048 Posts1,055,539 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Who carries 60-66 burb/panel body mounts or do I hafta make some. brian | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | anything like the pu cab mounts? alla suppliers have the hardware for those , and if its anything like the TF panel mounts, it's pretty simple to use the pu parts and bolts from the hardware store Bill | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | nahh red, they are different, they are rectangular & quite a bit thinner than truck mounts. I have some thick rubber that looks close, just not sure how thick they are sposed to be, they are kinda squashed after 40 yrs. brian | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | I just looked through my new Chevs Of The 40's catalog and coulda sworn they had some listed in there! | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Maybe Steele Rubber would have them? | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | Yup! www.chevsofthe40s.com Part #3685018A 47-54 panel or suburban. (09.009-4) $24.00 a set. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Sorry Mnsmith but mine is a 64, Jim Carter shows them for task force 55-9. brian | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | Doh! My bad! Should've read your original post a little better! I hope you find what you are looking for!! | | | | | Joined: Apr 2000 Posts: 247 Member | | Member Joined: Apr 2000 Posts: 247 | If you can't find them there are places on the web that will rebuild your stock mounts with new rubber. Don't have a specific link, but I have run across them before. | | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | steel rubber products rebuilds rubber parts. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | they look like rectangular rubber pads, really basic & simple. If I knew the correct thickness I could cut some out I spose. Energy suspension lists them for 67-72, I wonder if they are close to 60-66 parts. brian | | |
