3 members (delky, Hanks custodian, Rich'sToys), 127 guests, and 3 robots.
Topics128,149
Posts1,056,817
Members48,454
Hello, I know this is a Chevy / GM Forum, but I have a Ford question: Has anyone ever seen a 1940 / 1941 Ford Suburban? I have one, and I would like to get some more information on it. It looks just like a 1940 / 1941 Ford 1/2 ton panel, except for it has windows in the back just like a Chevy. And NO, these windows were not "cut" into the sides of the panel, they were factory die-stamped. From what I have found out so far, this may have been a military application. I cannot even find a picture of another one on the internet anywhere. Anybody out there that might have any info? Thanks, HISPEEDGAS - Michigan
Jed Offline
Hi Speed,
I couldn't find anything on an early ford with windows, but maybe someone here can help you out with some info...
http://www.paneltruck.com/links.html
Thanks for the info. I had a request for info on the PanelTruck.com website for a while, and I did get one response - from a guy in Missouri who had a 42 Ford Suburban. Unfortunately though, he knew as little as I do about the origin of these trucks. I will try to add some photos of this truck sometime....
Now you just can't come in here and talk about your Ford Suburban with out letting us see some Pix!!
1959 Chevy Apache-Suburban
5.3, 4L60e, Camaro Subframe, enjoy doing the work ourselves!
More on Hotrodders
Driving the past into the future.
best advice sell it on e bay buy a real truck a gmc or chevy
ya I know a few rednecks.Thay all drive chevys to,
Proud member of the Old Dominion Stovebolt Society
AND A MARINE
trucks range from 1942 1/2 ton to 1965 fire engine
Joe, It is not a sedan delivery. It is identical to a 1/2 ton panel. It also has barn doors in the back just like a panel. The front clip is identical to a pickup truck. The rear fenders are the same as a panel (I have 2 NOS fenders). I will have to figure out how to add photos of the truck. The front clip is not on the truck now, but you can still see by my photos what it looks like. Thanks for the info
Email me the pix and I can post them for you.
[email protected]
More on Hotrodders
Thanks for the help - I will e-mail the pictures to you. Some other notes on this truck: The rear windows are stationary - there are no window regulators. There is wood framing around the windows that held the glass in place. The guy I bought this from told me that the guy he bought it from had purchased it at a auction in the early 70's. He told them it had been used by the Air Force to transport soldiers to and from the tarmack. It looks like it spent the most recent part of its life working for some type of construction company, as the current lettering on the doors suggest. Again, thanks for the help.
Here you go.
I photoshopped 1 picture with a 41 front end. The angles where all wrong but it gives you an idea what it looked like.
[img]http://bwoc.org/images/ford/41panelb.jpg[/img]
[img]http://bwoc.org/images/ford/41panelc.jpg[/img]
[img]http://bwoc.org/images/ford/41paneld.jpg[/img]
More on Hotrodders
That was done, by one of the many Body Companys, that would build Ambulances, School buses, etc. Ford never had a Production Line vehicle,in the U.S. like this. Could have also been built, in another Country.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Contact the name on the side of the truck for information! Do some research in the town that it was from. I am sure you will find pictures and info. Did this truck have rear seats? Does it still have them? grin .....g
Garretthes, nice photoshop work!
I found some signwork on my 59 suburban while sanding from a bike shop in Phoenix Ar. I tried emailing them but never heard back.
More on Hotrodders
Companys like, Barnette, Armbruster, National, Franklin, & Protor-Keefe Body Co., did, have the capabilities, to produce, that body roll, spoken of earlier. I had a '48 Chevrolet Panel, once, that had been, one of these conversions.
Spanky Hardy
1950 GMC 250 1-Ton
Garretthes, Nice photoshop work! I have the original front clip to this truck. The front clip that you blended on to my truck appears to be from a larger model - I know the 1 ton and up trucks used a front clip like the one you blended. My truck, however, is a half ton - the front clip is identical to a 41 Ford 1/2 ton pickup. The 40 Ford truck is also the same front end, just the trim emblem on the front of the hood is different. I have the front seats, but no rears. I have also managed to find 4 NOS fenders - as I stated, the fronts are the same as a pickup, the rears are the same as a 1/2 ton panel. The remainder of the body on this truck is not too bad. I checked with the Henry Ford Museum, and they told me this trucks rear body section was more than likely done by a coachbuilder (like others had mentioned). If I give them the serial number, they say they can research it for me (@ $35 per hour)! These archives are also available to the public, so I guess I will have to go there sometime. Thanks for all the help, Bernie
Towe auto museum
Try these guys for information. They are pretty knowledgeable when it comes to Fords.
I would start searching using the information you found on the doors or any other written info that you have. Contact an old car club in that area, maybe even the local Model A Chapter. That was a pretty fancy truck in those days and if the family is still around, they might have pictures and a lot of history to go along with it. A well doccumented vehicle brings in a lot more interest.
Are yyou sure that it originally had rear seats like a Suburban or was the windows just for extra lighting? Are there visible seat mounts? grin ......g
Ford did have their panels converted for customers by several independent outfits. These were usually converted for the military, utility companies, and other commercial enterprises. Marmon Harrington made several in 4X4 packages.
Very nice truck, I envy you!
Baldbaron
