| | | Forums66 Topics128,062 Posts1,055,851 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#24495 02/25/2004 3:09 AM | Joined: Feb 2004 Posts: 6 Member | | Member Joined: Feb 2004 Posts: 6 | can anyone tell me what engine type this is from the picture, the guy who I am buying the truck off of says its a 216 but im not sure im a newbie to this stuff [img] http://www.villagephotos.com/viewpubimage.asp?id_=8069864[/img] | | |
#24496 02/25/2004 3:12 AM | Joined: Feb 2004 Posts: 6 Member | | Member Joined: Feb 2004 Posts: 6 | I stink at posting pics you can see a pic of the engine at t mack\'s truck | | |
#24497 02/25/2004 3:16 AM | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | Unless someone is trying to pull a fast one on you (by disquising the engine), that is a 216. If you can scrap off the crud, there is a casting number on the right side of the block, towards the front. Tell us that number, we can tell you exactly what you got. | | |
#24498 02/25/2004 5:47 AM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Tommy,
If I am seeing the photo right, the engine is orange? Passenger side of the block by the dipstick should be the #. Since the engine is orange, it has either been pulled and rebuilt or changed. If you have a newer full oiler 235, no big deal, but check it out if you are going stock. I am into the older stuff so I can't tell you if 235, 261 etc were ever painted orange in the first place. I can't tell ya much about the rest of the truck. I could not get the photos to go full size on the link. | | |
#24499 02/25/2004 6:13 AM | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Exhaust manifold goes straight down. Probably a 216. If the side cover continues up past the spark plugs, it's definitely a 216 or earlier.
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
