8 members (GRNHydra, David Bush, JW51, Oswald, Otto Skorzeny, Wally / Montana, Guitplayer, NJC), 104 guests, and 1 robot.
Topics128,060
Posts1,055,838
Members48,427
#24495 02/25/2004 3:09 AM
can anyone tell me what engine type this is from the picture, the guy who I am buying the truck off of says its a 216 but im not sure im a newbie to this stuff [img]http://www.villagephotos.com/viewpubimage.asp?id_=8069864[/img]
#24496 02/25/2004 3:12 AM
I stink at posting pics you can see a pic of the engine at t mack\'s truck
#24497 02/25/2004 3:16 AM
Unless someone is trying to pull a fast one on you (by disquising the engine), that is a 216. If you can scrap off the crud, there is a casting number on the right side of the block, towards the front. Tell us that number, we can tell you exactly what you got.
#24498 02/25/2004 5:47 AM
Tommy,
If I am seeing the photo right, the engine is orange? Passenger side of the block by the dipstick should be the #. Since the engine is orange, it has either been pulled and rebuilt or changed. If you have a newer full oiler 235, no big deal, but check it out if you are going stock. I am into the older stuff so I can't tell you if 235, 261 etc were ever painted orange in the first place. I can't tell ya much about the rest of the truck. I could not get the photos to go full size on the link.
#24499 02/25/2004 6:13 AM
Exhaust manifold goes straight down. Probably a 216. If the side cover continues up past the spark plugs, it's definitely a 216 or earlier.
